Muffler replacement
Tough Country Dually Running Boards
brake controller plug under dash in 2007?
I was thinking of changing out my exhaust to MBRP 4". The tailpipe is already 4" and how much really would the down pipe benifit being 1/2" bigger. So what i'm asking is, has anybody just changed their muffler? If you have ,what did you use, and did it fit nicely with the rest of the stock exhaust?
I'm running a MBRP mufler. Works well with a better flow and sound. If you go with the MBRP, you'll need to cut about 4" off you tailpipe at the mufler. Other than that, everythin is straight bolt on. Replacement pipe and mufler use factory hangers, and it's all clamp-on. I'm not bombed other than an air filter and gauges.
BF
I just ordered MK96116 From Dieselperformanceparts.com 4" Straight through muff with an adapter to meet up with stock pipes
No back pressure reading but my EGT's measured pre turbo dropped 75 degrees at all rpms. Have had my MBRP muffler on for 25,000 miles and still happy-no drone at all.
I am about ready to change mine also, I have an areo turbine,but not sure if i want to go to a muffler shop to get it put on and not like the sound,just looking for a little deeper of a tone. Is the MBRP a do it in your driveway bolt on ?
