My brakes squeek, what oil should I use
Ehgine Knock
909, 714, 619, 858, 760 trucks
I have been hearing a squeak every time I stop. What kind of oil should I use on the brake pads?
I am mechanically inept and need help!
2001, 3500, 2X4, QC, SLT, Auto, 3. 54 gears, camper and tow packages. Lance model 1130 camper. Rancho 9000 5 Speed shocks. BD Brake, autoloc, pressureloc. Hadley air horns. OEM bugshield w/eyebrows and dash cover. Member San Jose Ram Runners.
Red,
Don't know how many miles you have on your '01, or how you drive, but if you hear a squeal it may be time to look at your pads. . It may just be dust causing your squeal, but chances are it is not that easy. . If the pads look o-kay, I have used a brake cleaner from NAPA, it comes in a spray can and one can should do both sides of the front. .
You say that you are somewhat challenged by "wrenching" activities, but if you have ever changed a tire on the front of your Ram, you can take the front wheels off and look at the front pads. . They should have at least one-quarter inch left on both the inner and outer pads. . If not, better think about changing them or have them changed.
I bought Carbon Metallic replacement pads at AutoZone, and they are guaranteed for the life of the vehicle. . I have had them replaced once under the guarantee, and the counter guy didn't even blink, but I have several miles on my Ram.
Good luck!!
Rob. .
'94 2500SLT, LB, 3. 54, Automatic, TransGo Shift Kit, DunRite Convertor, TST HD Clutch Pak, TST #5 Fuel Plate, TST AFC Spring Kit, 16 sq. cm turbine housing, PacBrake, AutoLoc, EGT Gage, Mag-Hytec Diff Cover & transmission Pan, DeeZee Chrome Full Length Running Boards, Northwest Custom Rear Flaps, Vent Shades,. Pull 35' HitchHiker Premier WideBody 5th Whl (13,850+ lbs). 156,216 miles as of 1-24-01 Full Time RV'ers, Portsmouth, Ohio is "home".
Red,
What kind of oil ? thats like asking which is better, mineral or synthetic. You will get answers from both sides of the fence. One thing I would concerned about is the warranty. I'm sure you don't want to void your warranty and the way to avoid that is to use only Dodge approved semi synthetic brake pad oil. You can only get this special oil from your local Dodge dealer and my understanding is that it is on backorder. Seems to many of those Dodge techs were applying more to the left pads than the right hence the pull to the right problem so many of our trucks have, or was it to much to the right pads, I cant remember. Any way there is a TSB on the problem, think its TSB 00-BS-01 or something like that. Just make sure you get the right stuff. there are two different part#s one for front disc and another for four wheel disc. good luck
Y2K(BD. 11. 18. 99)PW7A BE2L34,(A4OP=ETC/DDX),DMDP w/DSA,AHJ,Autometer Pyro& 50#Boost,STD. PE,275RV injectors Psychotty,14cm2,Wlkr#21468
I've been using this stuff called Break Free,similar to Liquid Wrench,no more squeaks,only problem is I now have to put my truck in park to stop. #ad
the problem is with the dog,,a female dog who pis again a truck wheel,make it squeak but a male not! on a car, a male will make it squeak! a female not!
Wrench
If it's smell fuel, bring it over!!
WD-40 works great! The only problem is it does not last very long, it is best applied while brakes are warm and truck is moving. I don't advise the driver trying to do this on his own, its' best to have passanger (wife/girlfriend) apply. One last tip, slow to at least 30 mph before asking passanger to spray brakes!!!
Red,
They're all bull *&^%ing you. You do not need to buy any fancy stuff at the Dealer. I use my old oil after a change. Just turn you wheels hard to the left and dumb it on your brakes. Turn hard to the right and repeat. Mine have been squeak free since I did it.
I sure hope you guys are just pulling our legs and not putting any thing on those pads other than brake clean.
red,just to clarify,everybody here is BSing you,you should never put oil on your brakes. Some people go as far as using alcohol to wipe greasy finger prints off the brake rotor when working in that area. Most of the time dust is what causes the squeak,on my truck it goes away once I get off of dirt roads for a couple of miles. If it is a totally obnoxious squeak that makes folks turn their heads you can use products from the auto parts store that go on the back side of the brake pad,downside is that you have to remove the pads to apply it. By the time you go that far it often is just as easy to replace the pads,many are made not to squeak. Use no oil on brake surfaces. I hope you were joking to begin with.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,BD E-brake,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
[This message has been edited by illflem (edited 01-29-2001). ]
PUT THAT GOOPY STUFF BETWEEN THE PADS AND CALIPERS... IT'S MADE FOR THAT... COME ON BROTHERS OIL AIN'T FOR DA BRAKES!
9535hundred
You guys that have replied to this owe me a dry pair of skivvies as I have just pi$$ed my pants laughing at the oils recommended. Semi-synthetic brake pad oil, that is the best one I have heard in a long time! Gotta go change.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S Everything but leather NRA Member
abledog
Now I know why you have those huge custom made running boards on your truck. you mite want to add a couple a grab handles to the front fenders, hate to see you lose your applicator, or maybe it would be best to run a couple of hoses down to the brakes with an in cab control.
[This message has been edited by WeirCummin (edited 01-30-2001). ]
Often the sound of squeaky muffler bearings is mistaken for brake squeak. #ad
Remove the muffler and see if it goes faster and jumps higher. #ad
9535hundred
Thankfully we're ending this discussion. . I was afraid we'd see someone post their oil report which proved that brand X was better at reducing brake squeal DB levels.
This was a funny thread though . . and hope the original post was in fun!
Michael
The sqeak is caused by your front pads moving(unless they are wearing out) about on the calipers, as illflem suggested they make a glue compound for this. To be applied to back side not front.
Don't feel bad red1ton there seemed a few others that thought you could oil your brake pads. Hope all of were just spinning your wheels.
Hey thanks for all of the good advice. Since I could not find the semi-synthetic brake pad oil, I used the engine oil from my last oil change.
The squeak is now gone but I still have a stopping problem. I use the exhaust brake to slow me down to around 28 mph. I normally use a tree or telephone pole to finish the stop. The front bumper is not holding up well and the front license plate fell off the other day.
When I back up I try to RAM into something using the trailer hitch. It is hard to line up the stopping post when I am backing up.
Next time, I will add some sand to the oil. Maybe that will help with the new stopping problem.
Is this brake problem covered under my 10000000 mile warranty?
Don't forget to do regular analysis on the "brake pad oil", that is the only way to know when to add more or replace it completely.
Larry
And you better watch out for high sillycone levels if you're running a K&N filter on those spindle intakes.
red1ton:
If you read all the discussion forums every day, you would know that Amzoil is the brake oil to use. It lasts twice as long and brakes twice as much when you must use your bumbers to stop. Your front bumper problem can remedied by the addition of DC tow hooks or a front receiver with a giant hitch in it.
Another product which may help your slippery brakes is a new, soon to be released product from Amzoil: Synthetic Truck Wax. It's so slippery that you will no longer 'bump' into those trees and lessor pickups. You'll just slide by!
