Thanks Animal. ATS doesn't mill the stator thinner, like the early BD example on pg. 51 of the latest issue (36) of the TDR. Milling is actually not the best word to describe the machining they do to it. They use a 4-axis CNC machine, which is computer controlled, to machine each stator blade from different angles to create a spoon-like shape. This makes the truck GO FASTER at lower speeds.
You're familiar with a woodworking router right? Think of a 4-axis CNC as a big machine which can hold a bit, like a router, and push that high-speed bit, into the stator blade from any of 4 different directions all the time while being pulled and pushed around. The result is the machine can take the fat teardrop shape of the original stator, and turn it into the spoon-like shape which Don & Clint came up with.
I think the reason the factory didn't do this in the first place is, (A) Their engineers were not as motivated as Don & Clint, and (B) It is probably more expense than the executives wanted to spend.
As far as stall speed, I don't remember exactly what mine was before, but this is what would happen: I would mash the gas from a dead stop and the rpm's would climb to about 1800 and the truck would slowly take off.
Now I mash the gas and the truck runs like a violated primate. RPM's don't go as high, from a dead stop, and when it locks up now, the rpm's don't drop as much. Now they only drop a couple of hundred when it locks up. I'll observe it some more and keep reporting.
