WOW :--) The pump alone makes more power than the VA and 275 injectors do. There is a lot of low end smoke, but boost builds really fast, and with the VA off, boost is now up to 35+ instead of 30. It idles almost exactly like stock, but it does skip under no load from 1200 rpm to 2000 rpm. Not bad though. It also did away with the low rpm shudder under light load that the stock pump had. It holds 1000 rpm coming to a stop, which seems to help the braking, and it does not return to idle as fast between shifts, so that will take some getting used to. So far, I am very impressed.
