My HTB2 install experience
TV Today - Spike - Banks Cummins/Hot Rod Truck
banks on xtreme 4x4
JStieger
After 2 months of research, searching old threads, and PM'ing numerous members I decided to purchase and install a HTB2 turbo with the "62" compressor and 12 cm2 exhaust housing as recommended by Paul at HTT for my BOMBS and driving intentions without killing driveability. Well, now i just can't get the smile off my face!
The turbo install was basically a bolt-in that I made more complicated by my stubborness, but I want to share my experiences to make future HTB2 installs a breeze for other TDR members. The HTT turbo came with all necessary bolts, gaskets, and O-ring. I also purchased the downpipe with clamps and turbo compressor outlet and clamp.
My installation took about 11 hours only because I worked on it mostly by myself and I was fighting a losing battle with the downpipe. If I had help from the start (and some of the following tips!), the install would have taken 5-6 hours. Here's my tips:
1) Soak all bolts/nuts/clamps with penetrating oil up to a week in advance.
2) Invest in some metric open end and box end wrenches. 15 mm was the size for the turbo mounting bolts. The ratcheting type and stubby type work extremely well in the close spaces that are even tighter when the HTB2 is installed.
3) Invest in about 1' of 4" exhaust pipe, 4" 90-degree elbow, and some exhaust clamps for working with the new downpipe to your current exhaust. The 90-degree elbow can be cut down to any angle and the new downpipe was about 8" short due to the amount of my stock exhaust that had to be removed. If you don't want to do exhaust work, at least purchase some 4" flexible exhaust duct as a temporary splice.
4) Remove passenger wheel well liner. In hindsight, removing the passenger wheel would have helped some more.
5) Disconnect negative battery cables from both batteries. Cover up terminals with non-conductive material. I found that I was spending lots of time with metal tools over the passenger side battery!
6) Install the cleaned-up stock intercooler boot on the compressor outlet with the outlet in a vice. The stock intercooler boot is 2 7/8" ID, but the HTB2 compressor outlet is 3" so there is quite the stretch. The stock boot is very stretchable yet strangely kind of feels like old newspaper. I have a 3" silicone hose to install, but the stock clamps were too small. New clamps on order.
7) Get your friend and install the HTB2 loosely. Attach the compressor outlet and note the limited clearance between the shock mount and outlet. Remove turbo, take to bench, mark with felt pen some reference marks, and clock the compressor housing to gain your clearance. Reinstall on truck loosely and check clearance. Repeat above as much as required. I did this twice before my friend showed up. Use your friend's help; your lower back and legs with thank you!
8) On the bench, attach the oil drain tube. Hook up shop air to the wastegate hose to activate the wastegate. A tire pump could actually work too I guess if no shop air is present. You will then see where the wastegate actuator hits the tube. Mark location and remove tube. Dimple the tube only SLIGHTLY in at this location with a SMALL ball peen hammer. Reinstall oil drain tube on turbo while on bench and triple-check the clearance. Make that quadruple-check including that the oil drain tube bolts are tight. You will thank me later because I wasted an hour trying to install the oil drain tube while the turbo was on the truck. Did you install the oil drain gasket? Just checking!
9) Reinstall turbo loosely in truck. Prime turbo with fresh oil while spinning it with hand to make sure that oil is in fact coming out the oil drain.
10) Friend can now hook up oil drain to engine block, while you move loose turbo around to give your friend clearance. Install oil inlet with new O-ring.
11) Rotate steel intercooler tube 180 degrees (not end-to-end) to get your alignment with the compressor outlet.
12) Tighten turbo mounting bolts, intercooler clamps, and oil drain clamps.
13) With friend's help hook up downpipe and tighten clamp. Adapt downpipe to existing exhaust.
14) Bump starter without starting engine to build oil pressure. Check all oil fittings for leaks.
15) Start truck up, idle for 5 minutes, and again check for leaks and strange noises. Then go drink some beer because you deserved it!
For some reason I had the wrong downpipe from HTT and the lower horizontal portion hit the floorboard. I had to run with an open downpipe for about 50 miles and 4 days with windows partially open in 20 degree weather (WHAT!!! I CAN'T HEAR YOU!!) until I could get the custom exhaust shop to make that downpipe work. In the end this was a blessing because I had them replace my stock 3. 5" exhaust pipe to my 4" straight through muffler with 4" pipe. Paul at HTT is aware of my problem downpipe and chasing down current stock as well as with his supplier to double check for proper fitment.
Initial performance (limited) observations due to turbo break-in:
*Spoolup feels same as stock.
*Cruises at 4-6 psi less boost than stock, but at similar EGT.
*Light acceleration in town, i. e. stoplights, about 100 F EGT higher.
*Interstate on-ramp with Power Pup on performance/extreme at 80 mph
-stock = 22 psi and 1250 EGT
-HTB2 = 22 psi and 1000 EGT
*No surging
*Turbo whine? Gotta love it!
The HTB2 will work with a Scotty RA3 without any modifications. I read that with the AFE you would have to notch the bottom of the airbox.
I have a VA C3. 1 coming for a stack and for the boost fooling shortly.
Final thoughts:
Would I do this again in a heartbeat? You bet!
Would I deal with HTT again in a heartbeat? You bet!
Pictures are in my Reader's Rig gallery.
told ya you'd like it :D As for the EGT's being slightly higher on light to light driving. My buddies is the same way for some reason.
if you think it spools up nicely now give it about 1000 miles to break in and seat the bearings and stuff and youll absolutely love it. im sill having some surging issues with mine :{ . but i have an auto and i think its is partially due to the tight suncoast converter that i have, and when the rpm drops dramaitcally with about 25-30psi at OD , the engine cannot ingest all the air that this turbo is feeding it. im gonaa order a TAG III and see if this helps with the surging issue at all. otherwise im just as happy as can be! Oo.
wes
Lmills-
Actually, I had it narrowed to the BD Super B and the HTB2. As far as pricing, both were essentially the same. BD had the 1-year warranty and the bolt on twins kit; HTT had a slight edge on the rated HP and had demonstrated to provide service after the sale above and beyond the call of duty. Both had strong supporters that gave good, no BS reports. It was you, Lightman, and SRadke that convinced me to make this choice. You also posted about your friend that had the non-Killer B2 HTB2 version with the mods that were similar to mine and the fact that he was pretty pleased with it. In the end, the other really strong deciding factors were the positive service experiences that everyone commented on with HTT as well as the fact that they are down the interstate 3 hrs from me (close by Nevada standards!).
WDimig-
I was initially hell-bent on the Killer B2 version, but then realized that my intended mods and usage would not be enough to use it to its full capability or even "drive the turbo". Paul also stepped in and steered me to the regular HTB2 as the best for my application that would not result in the surging that some other way more BOMBED people were experiencing with the Killer B2. It's actually a blessing for the turbo break-in that the roads are crappy here under a "Winter Storm Warning". Otherwise, I wouldn't know what to do with myself!
JStieger you are turning that truck into quite a beast!
Next time I'm up in your neck of the woods I'm gonna come lookin for ya. Oo.
It's nice to see you adding the power mods the right way. :cool:
Awesome post! I ordered my HTB2 a few days ago. Only difference is mines clipped so it'll act like a 62/13. Ordered all the parts and pieces you mentioned. Everything will be here next week. Glad I got to read this. I'm printing it out and am going to use it. Thanks.
I was installing my htb2 this afternoon and this tread helped me a lot. But I would like to add some to it. For my setup I have a PacBrake, so the compressor housing has to be rotated counter-clockwise. As for modifications I had to cut on the end on the pacbrake braket, the shock mount cap, and the AFE air filter. Once I know how to do it It would not take long, but sinse I didn't have any directions It took a little while. If there is interest I will post some pics.
RWood-
That would be great if you could post some pics! Which HtB2 did you get and was it on your '05? I'm still liking the HTB2. It's held up so far to my TST and VA stack. Just when you think the EGT's look to be getting hot, the boost kicks up and does its work along with the wastegate. I have not gone above 5x5 on the TST plus 100% VA on a continuous basis yet though as this is the level where I feel comfortable at without having to be glued to the gauges 100% of the time. Makes for a lot more relaxing, yet fun ride when not having to be glued to the gauges.
This is a great post. I did 1 thing different on the oil return line. Insead of pulling out of the engine block you can put the return line with turbo on truck. I spent lots of time trying to get it on untill a wrench hit me in the head and I had this idea. We put the inside bolt (inside meaning next to wastegate) into a vise and used a hacksaw to cut a slot for a flathead screwdriver. You can then line up gasket, push line up to the turbo, use a retractable magnet and place the screw in the hole, hold with your finger while you remove magnet and slip the screwdriver up to the bolt. With a long enough screwdriver its very easy to get this bolt started. Then start outside bolt, go back and tighten both.
My 0. 02 hope it helps
Is your pac-brake the turbo mount or inline style. I thought this turbo would not accept a direct mount brake. If it did how much fab did you have to do to make it work. Thanks for any info.
I put the HTB2 on my '05. The PacBrake is a direct mount and I just had to do some more modifications. I think that without the PacBrake I would not have to have had to cut on the shock mount. If I had to do it again I would probably get the in-line for this reason.
I printed these notes out and took them with me. They helped a ton. I had the stock one out and the new one in in about 3 hours. Having the down tube from HTT helped even thought the angle was wrong. Bought a 4" flex before I tore down and I'm glad I did. Thanks again for the hints and tips.
