AH64ID
Read the third page he posted. "The air suspension system is a closed system."
It also says the compressor will recharge the reservoir from atmosphere, which is what mine most certainly does.
I think FCA is misusing the term closed system on page 3, as it is not closed the way we are all used to closed being.
It appears to work like a really fancy aftermarket setup. Compress air, store air, and move it in/out of the bags as required.
The reason nitrogen is required for the initial/maintenance fill is that allegedly the compressor will set a code if it has to run long enough to fill the system from 0 psi.
