I’ll disagree a little on the fact of same fuel used, at the weight of fuel per gallon when bob tailing, is more weight to push.
But the cost of carrying those extra 23 gallons is more than offset by fewer stops, trundling around parking lots, and not having to keep getting the load back to freeway speed![]()
On the plus side, unlike the extra passenger, the effects proportionately decrease over the couple hundred miles added between anticipated fuel stops, unlike the addition of unscheduled pit stops, adding time and fuel consumption, required by an extra passenger. Three more teaspoons of fuel saved.Plus, it's only about 165 lbs....just like carrying one extra passenger.
On deep analysis I can think of at least three:If only there were a solution for a tank allowing more fuel than one is willing to purchase/carry.
1. Life's too short - Remove that trivial concern from one's thoughts;
2. Share the wealth and boost the economy - Purchase passage with an alternate mode of transportation;
3. Stay healthy - Walk...
Ooo! Ooo-ooo! On EDIT: Why didn't I think of this earlier? So, are you ready for #4?
4. An ELASTIC fuel tank.
With an elastic fuel tank you can pump as much fuel as you desire into it, all the way to the point where the vehicle looks like a pot bellied piggy dragging its tummy on the ground, of course better utilizing the fuel tank's skid plate that normally just dangles in mid air. And, it would always be a full tank of fuel, no matter how much fuel you put into it. You can add precisely as much as you desire at any time. Never too much; never too little (unless you run out).
Oh Magoo, you've done it again!![]()
On the first, initial analysis.....
1. Don't fill the tank all the way.![]()
Some pumps automatically stop at $50. Others are programmed to automatically stop at $70, $75, and anything up to $100
That should be accounted for in the algorithm with a factory tank.I considered the Titan fuel tank, (for my '17) but heard they couldn't adjust the computer for the DTE to be correct. I'm hoping that's a non-issue if the 50g comes standard on the 2020s.
Nothing wrong with pulling over for a personal pit stop. The back roads aren't like the big city; ain't no stinkin' fuel station behind the cacti out in the desert or rocks in the mountains. Try the desert in southern CA...next services 278 miles, and you've already put 200 miles on this tank. Fuel costs at either end of the trek are double what they are elsewhere. Nice to have a few extra gallons to get you past the money magnets.I am not criticising anyone for putting a BIG fuel tank on or under their truck. But it seems that no matter what you are pulling, you can go for at least 2.5 hours and more likely you can go 3 hours on 30 gallons of fuel. It actually makes sense to stop and rest after a few hours especially when towing to keep your brain and buttocks fresh. (Assumes 6-8 mpg)
Remember it was recommended to keep your tank full to prevent condensation/water from being pulled from humid air by ULSD in your tank.
Not if you have a Pilot/Flying J card or one of these:
https://www.tsdlogistics.com/services/fuel-program/
AND going to places that are off the beaten path.
