gsbrockman
Here’s some low numbers.....of course my truck is a 4500 Cab & Chassis, weighing in at 10,860 lbs and is 4.10 equipped.
Road Trip HD.....for Apple products. The one you see is the paid version....they have a free or reduced version, but it does less. I think it cost around $10
I’m sure they offer it for Android devices as well.
Seems to be for Apple only...Road Trip HD.....for Apple products.
Are you seeing the same numbers as Tom ?. Those just came as a shock to me as I do not think anyone has posted solo numbers that low.
OK, here is the overall MPG for the first 5268 miles, its a bit disapointing, but it includes towing 5ver and boat at times. I seem to drive a 50/50 mix of city/hi-way. I can break down the MPG with the 5ver but it wouldn't be accurate, due to fillups before and after in the empty mode. 13.836 MPG and the DEF is 526.8 MPG, this is hand calculated.
I'm still waiting on a permanent solution to the "welderup drag link recall" myself. In the interim, paint marks and routine checks work just fine. Can't say I blame you for a "wait and see" approach on this one Tom.
I've also received several notices/calls. Every time I speak with a person I explain why I will not proceed with the recall until a permanent solution is available. I don't think I'm getting through to anyone.I got a second or third call about the drag link recall on Feb 27th and they took info on which dealer to ship the part to, as I said I did not want it welded. Left a message an hour ago with the dealer to see if they have seen the part.
Has anyone considered getting the revised drag link, having an independent shop replace it, then submit to FCA for reimbursement?
