I hate this trans... it shifts poorly, it eats fluid, it is a PITA to change fluid... but at least it is supposedly stout?
Just got done replacing the fluid in the NV5600 last night... got almost 20k out of the Redline MTL/MT-90 blend, which is by far the longest I've gotten out of any fill of synchromesh-type fluid. Starting about two weeks ago, shifting started to drastically fall off... almost impossible to hit 2nd in the morning... had to baby every shift in order to not get a little bump (gear clash). It was mainly 2nd that was the problem... but there was no normal shifting of the trans (it was bad enough I almost got rear-ended by a Stratus... the pause between shifts isn't something the other drivers are anticipating). Not to mention the fact the trans was starting to run warm... it was heating up quicker, and a little higher than it should normally do. A UOA last year of another synchromesh indicated the fluid shears in this trans... that causes my increased shifting difficulty.
Ordered 7 quarts of MTL from Summit Racing on Monday, got it last night. The bottles of MTL now read that it is a synchromesh fluid... which is new. Decided that since it was winter, I'd just use straight MTL, and leave the MTL/MT-90 blend for summer.
Did a quickie drain and fill, didn't pull the side covers (this leaves around 0. 75 quarts of old fluid in my trans). The fluid drained absolutely clear and red, just like when I installed it. And the magnet was completely clean. Refilled with straight MTL (short what was still in the trans) and got around 6. 5 quarts in the trans (it has Fast Coolers). This was the first time I actually didn't end up wearing half my fluid change...
Take off this AM... I can hit 2nd fine, but now its cranky going into 3rd...
Overall it does shift better... and it rolls a ton easier (I feel this might be where some of my mileage has been lost as of late).
I'm starting to drive it like a 3-speed... 2-4-6 shifts instead of the typical row through the gears. This doesn't seem to lug the engine at all and no clutch slipping is needed, and is a lot easier on the flats to gain speed... it is one of those things, there are only certain places you can get away with it, you got to know when...
Its hard to believe, but I've actually change the fluid in this trans more than I have changed the oil in the engine...
steved
steved
