Well I bought a pair of 4" rain flaps and now have them installed but wired shut due to the frost, fog and cold temps.
I did pick up a pto style cable with a screw type head that I will mount in the cab, I have also ordered a air temp gauge from westec that is special order for a range of 30*to 150*, when installed I will simply adjust the cable to the flaps and try to get 80-90* at my airhorn.
I plan on building a steal scoop to mount under my bumper or in the bumper if I can and on the front of the scoop I will build a butterfly valve (plate) to be the temp control, the scoop will have 2 connections on the back of it for the 3" ram tubes to connect to. the front of the scoop will be like 4" tall and say 6" wide.
cheers, Kevin
cheers, Kevin
