I see Gary Owen has already addressed the issue of the combination being a passenger vehicle or commercial vehicle.
Gary knows what he is talking about and his statement is correct. The truck's owner uses the truck and trailer for a commercial purpose and the combination is therefore a commercial vehicle.
The truck, trailer, and driver are subject to all commercial vehicle rules and regulations including commercial vehicle inspection decal if one offered in SC, mounted fire extinguisher, vehicle registration and proof of commercial insurance policy carried in the cab, driver's log book UNLESS the truck and trailer operate daily within a 100 mile radius of the home terminal, stop at all scales, etc.
Mark above is also correct. The rear axle of the truck is probably (almost certainly?) overloaded and will result in an immediate out of service order and a large fine the first time you encounter a
SC DOT car or whiz past a scale.
Ken, I think you are as naive about commercial motor vehicles as you are about brake controllers. You would be wise to drive your unloaded pickup to the closest SC DOT or HP office and begin learning what you've gotten yourself into.
On edit: You are also required to have DOT numbers and the company name and DOT numbers must be displayed on the side of the truck at all times.
Second edit: In backing out of the thread with the back button I paused to look at the photos and realized that is a tongue pull trailer not a gooseneck. That is probably going to turn out to be an expensive mistake. With the way the trailer is set up and loaded so heavy forward the tongue weight probably exceeds the rated weight of the hitch and an experienced DOT officer will notice and check.
