Engine/Transmission (1994 - 1998) Mystery Switch Instructions
Engine/Transmission (1998.5 - 2002) fuel pressure gauge
D
Engine/Transmission (1994 - 1998) Lift Pump?
97 With Mystery Switch
I installed the mystery switch as per TST's instructions and it looks and holds. The only problem is that when I leave it locked for a long trip, the trans must be overheating, because when I turn the switch off, the trans will not downshift when you stop. Any ideas on this? I do not have a trans temp gauge.
I found just tapping into the wire TST suggests was giving me problems. I split the wire and hooked up that way. I also had the reflash, and have had no problems with the Mystery switch.
