NAPA Fuel line compatability for Diesel Fuel?
double-clutchin' dimmer switch
Hard starting
Dealer wants $43 for 6" of fuel line... .
Anything special about this diesel fuel line?
Or can I use the ordinary 3/8 & 5/16 fuel line found at the parts store?
Thanks for your help! #ad
94 2500HD 5sp 4. 10LSD 4X4 ABS w/GearVendor OD, K&N Oval w/ Pre-Filter, "STRAIGHT" Exhaust, Geno's Fumotovalve, 123,000 miles. NRA Member. V1.
Ordinary gas hose cracks on the outer layer but i've used it. It looked OK inside. See if NAPA sell hose for diesel. I've gotten transmission cooler hose at NAPA before - maybe that would be better! Craig
I have NAPA fuel hose on mine for about the last 20,000 miles. So far its OK.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors,16cm2 turbo housing, Pacbrake, Walker muffler,
GearVendor O. D. , CenterForce Dual Friction clutch.
Eastern PA.
When I tried regular gas hose, it was on an Olds diesel(20 yrs. ago). It wasn't NAPA. It sounds like they have good stuff! Craig
You ought to do like I did and tell the dealer that you were born. But not yesterday. They **** me off so bad, Its no wonder that they are having layoffs. They quoted me $4. 90 a quart for ATF+3. Napa has valvoline ATF+3 for $2. 39 a Qt. They said they would soon have NAPA brand ATF+3 and it will be lower in price than the Valvoline. 5 turds wanted $40. 00 for an upper radiator hose, NAPA sold me one for $10. 00. Serpantine belt DC- $39. 00, Napa- $18. 00.
I just go to DC as a last resort. You think the fools would realize how much business their losing. By the way buy all your filters at Cummins.
See Yaa
D McGrady 1996 Club Cab 6BTA 5. 9 12 Valve All Stock Except K&N and Wrangler A/T 305/70/16 136 K and going strong.
McGrady, I have been buying all my filters at NAPA also!! NAPA Gold series... made by Wix, and sweet prices too!
97 2500 CC 4x4 3. 54 5spd, Green, #12 plate slid all the way forward, 4inch open exhaust, 235/85 Michelins, RS 9000's, PrimeLoc, Red Tops, TDR cloisonae grill badge!
Hey Rebel, thanks for the tech spec. Got Gates hose @ Carquest w/ that spec. When did you receive Issue# 31??? Don't have it yet...
My hats off to any one who replaced this hose completely from the top! Not possible for me, mebbe me arms are too short! #ad
Hose was cracked completely thru so I didn't have to worry about fuel coming out since it had already leaked out. Can you believe how the dealer is trying to "HOSE" ya w/ these prices? Yes, that pun was intended! #ad
Mike,
Got my TDR 31 last Thursday #ad
Did you by chance make it to the Rocky Mtn TDR chapter meeting? I intended to go, but ended up working #ad
1997 2500 Ext Cab 4X4,5 spd,3. 54's,Pac brake,Rancho 9000's,Centerforce clutch,K&N airfilter, Isspro gauges,TST #11 plate (280hp/680tq),AFC medium spring, Jardine 4" exhaust, 370 Diamond B marine injectors and 16cm turbine housing.
Had to replace mine last month, it ruptured and was spewin' fuel like crazy. The dealer had replaced it a few years back to fix the hard-start problem when my Dad owned the truck. After I got the hose off, I could see two deep grooves where it had been rubbing between the fuel filter mount and the engine. These are pretty sharp edges. Funny though, that's not where it ruptured. The hose was rated J30R7, which I believe is rated at 50psi, and other than the chaffing, it looked fine. Don't know why it failed. Anyway, I routed it pretty much the same way but placed a plastic sleeve over the hose to avoid the chaffing.
Needed only to pull the fuel filter and was able to do it all from the top. Using a spin-tight made that possible. Still had major bruising on forearm though.
R. ebel
You must have better post service.
Got my TDR 31 last night. #ad
Rocky Mtn TDR chapter meeting? #ad
I plead ignorance. Wasn't aware. When was it? What was the agenda?
