OK Guys here's the deal. I found a Walbro replacement pump - same exact unit @
http://www.gsl392.com/ for $95! That I got when I originally ordered my system from Glacier. Unfortunately Glacier no longer offers them = went to supplying FASS units.
And then...
I ordered up 2, 3/8" fuel line unions w/1/8" tap for gage, new VP44 Overflow valve, Engine Barring Tool and a Cummins "Oil Engine" cap from Geno's Garage. Why the purchases?
* 2, 3/8" Union/tap - During one of my "hunting/troubleshooting" excursions recently I think I cracked the original fuel line union where my FP sender was when I removed the sender and installed a bunch of fittings and hoses for the mechanical test gauge (that I taped along the body up to the top of the windshield so I could see what was going on as I drove) as when I returned home it was leaking fuel. Why 2? So I could compare the in A-pillar gage to the mechanical one, and to have an easy to connect up to port the next time I wanted to check psi w/mechanical gage and not have to worry about disconnecting the sender unit/damage it when doing so.
* VP Overflow valve - I removed the one on my VP and testing "seemed" like it wasn't functioning correctly, heck what's another $35 = cheap insurance.
* Engine barring tool - not related to this lack of FP expedition, just always wanted one, a real PIA when adj valves or lining up timing marks etc turning over the engine with the alt pulley.
* Cummins Oil Engine Hat - so we really need a reason why? Didn't think so.
So here's what I did after all the parts arrived and I finally had a decently warm day to work (oh, truck has been OOC for last week as I had a fuel leak and was just too cold to address "and" waiting for parts):
* Tried on the hat - ohhh baby dats nice.
* Looked at the barring tool - ohhh baby dats nice too then put in the tool box.
* Tested the new Overflow = same results as the original one. - Ohhh baby dats nice too and put in spare parts storage with all the other ohhh baby dats nice items.
* OK enough BS:
Removed the fueling system (partial) assembly following items: hose before and in-line pre pump screen/filter, pump, sender unit and hose after to the Tee = 1 outlet to reg valve/back to tank & 1 to spin on fuel system filter.
Upon setting this up on the tailgate as a pattern to install new hoses (just in-case there was a "flap" inside one of these hoses) and the new components I noticed something that for some reason "totally" escaped my prior extravaganzas of trouble shooting... . the pre-pump in-line fuel screen/filter had a date of "06/07" written on it "by me" = D'oh!!!
Before I continue I must admit, other than being a friggin knuckle head and not noticing/changing this in-line filter/screen when I last changed the spin on FF ( less than 1000 miles ago), I was pretty ticked off that I ordered all this "stuff" (and after trying to catch up on my TDR reading - most recently read issue TDR77 of course I started reading this "after" ordering all the stuff mentioned above) and a bit embarrassed at my lack of attention I wasn't really planning on sharing my idiotic-ness here. But, especially, after reading some of this (TDR77) issues articles with the Theme of: "wish I'd known that before I... . " There was "no-way" I couldn't put one of my own "ah, ha!" moments out there to: 1-give everyone that's been trying to help me on this a "good laugh" at what stupid idiots we can all be at times and 2-a "don't forget to check the small stuff first! Reminder to all of us.
OK, back to the point.
So, after noticing the date (06/07) on the pre-screen/filter "and" after a few choice expletives to myself, I took my trusty Harbor Freight hose cutter and cut the hose between the screen and pump, wiped off the inlet from the tank side of the screen and "tried" (yes tried) to blow thru it..... Of course... . "It was friggin blocked!!!!!" Double D'oh!!!! The friggin Walbro was fine, and yada, yada, STUPID IDIOT!! and "Oh whata-goose-I-am". Arrrggghhhh!
OK, so at this point I figure what the heck and continue with the install new hoses on the new pump, hose to the new union, hose from new union to the Tee and swap the FP sender onto the new union. Install new partial fuel assy. Connect up all electrics - making sure to test the red wire from relay to the new pump was indeed the "+" wire before connecting everything - see previous "you friggin stupid idiot" moment.
OK, everything looks good, let’s see if we can fire up and make some smoke. I turn the key to on, wait to start light on, and no PSI on the A=pillar FP gage? Jog key to start once, still nothing, in fact it reads negative? Now WTF! I get down under to make sure the new Walbro is running - yep, why no FP? I'm getting really good at finding my stupidity = probably would have been a good idea to turn the fuel from the tank to pump system valve "on", unbelievable... .
So, back up and try again, still no PSI? Now what... "F-it" started right up running like a charm = YES! and also remaining, WTF now?
So, I shut down and swap the red/black wires on the sending unit. Results "BAMB" same friggin thing 0 PSI. Install the other new union and connect up hoses and mech gage. Fire up and this time for real "BINGO" 19 - 20# finally a real "YES!"
So, before heading down the road to see what happens at varied go pedal positions I wire tie (the new age duct tape) all the hoses so they're nowhere near anything that could create an issue - see there's hope for this idiot after all - and then run the hose under the back door (OC truck) wire tie the hose the gauge is connected to onto the 4X4 shifter so I can read it and down the road I go.
Finally, success! Rock steady once again = very little fluctuation at any go pedal position even with the Edge Comp on "KILL".
At this point I'm pretty disappointed with the Westach sending unit as this will be the 3rd one that's gone (or that I "caused to" go) bad in the last 11 years since I installed the gages (right after I bought the truck in 05/01 w/5k miles).
What really ticked me off even more (about Westach) is I went to my trusty Geno's Garage catalog to order up a new sending unit I noticed a few things in the Westach line-up of products.
1-There's a new fuel pressure gage that displays on the face of if "Diesel Fuel Pressure" with the sending unit. Ohhh baby dats nice but for $215. 00 it'll stay right there in the catalog.
2-I go to "Westach accessories" and find the replacement sender unit is "$135. 00"!?!?!?!?
3-"But wait there's more"!!! This sending unit is "only for" the gage that displays "Diesel Fuel Pressure" on the face.
WTF!!!! When I originally purchased "all" my Westach gages; Combo Boost/EGT, Trans Temp & Fuel Psi, along with "all" the senders and probes needed to connect up "and" the tri-pod A-pillar "and" paint to match, all this cost about $500. So now I have to pay almost 50% of that for one gage and "only" because the $135 sending unit is "only" for the new gage.
The last time I replaced the sending unit it was like $40! OK rant complete. I'm hopeful I can contact Westach direct and get a replacement sender. Of course before doing so I'll check the air in my tires to make sure that's not the problem-LOL. Actually I'm hoping it's a loose wire somewhere instead of a "loose nut behind the wheel".
I hope somehow my story has at least made someone laugh and/or maybe share a bit of 2 things, 1-check the stupid/small stuff and 2-when you put a date on something so you know when it was last changed - make sure that date isn't covered by the mounting device so you can "actually" see it... .
Happy Easter and/or Passover
