Need help! Green light on, no trailer on.
Hi all,
I am currently loading the RV for 2 months out West and yesterday noticed the green light is on on my Tekonsha Voyager. The problem is is that there is no trailer plugged into the socket.
Here's what I have. Under dash controller 4 wires, butt connected into an adapter to plug the controller 4 pin to the factory Dodge 4 connector. All connections good here.
I did as tech support said, cut the Blue wire feeding controller, and green light goes out. Indicating a short??
I separated the 4 pin connector, using Volt/Ohm meter checked female plug end of factory I found a direct ground connection on 2 of the pins, instead of one, I assume it should show ground on one, and 12+ on the other.
Checked fuse under hood for trailer brakes and found it good.
Climbed under truck where I have an additional socket installed in the truck bed, it appears the RV dealer spliced into the factory harness that runs to rear under bumper mounted trailer hitch.
Everything here seems fine. No loose connections or splices done poorly.
I am running out of time, I need to leave here either Tuesday or Wednesday at the latest.
Anyone with some knowledge of the wiring or what I should check would be appreciated. I have 30 year experience in electronics, so not much I cannot check, but don't have the time to spend troubleshooting without a wiring diagram.
Thanks,
David C. Miller
Marbleman
Hi all,
Thanks,
David C. Miller
Marbleman
