Archived need a new 5.9
Archived '03 4x4 front shock lower bolt
Archived Gasoline in Diesel Fuel in Friends Duramax???
I had #1 cylinder score and dropped a valve seat on my 2003 the guys at Stadium International said they had seen it before when a common rail injector sticks open. They put in a Jasper reman engine It was complete drop-in. Take your wallet with if you go that way, I went that way do to I needed the truck up and running it took 2 weeks to get the truck back. So far having good luck with it has 2 yr. on motor and 1yr. on fuel system
sfritts I ordered a long block from Blacks diesel performance. I should be up and running soon. what fuel system did you go with. I've been looking at airdog
I'm still using the stock fuel lift pump and use the 7micron fleetguard filter, I have to stay with stock system to keep up the warranty
