Put on a set of Bilsteins about 2 months back... ... buddy and I did shocks, brakes, track bar, etc all at once. He did the front shocks for the most part..... I'm getting a clunking noise when I hit bumps, so checked the shocks and towers, and found all tight except the retaining nut on top of the front shocks. When we got these shocks, there were NO instructions, no nothing for reference. Just shocks, and large washer/grommets and nuts for the front. The front shocks have a large washer on top of them, followed by what appears to be a big rubber grommet that has the large part under the tower, then a piece that goes thru the tower and out the top..... on top of this rubber piece is another washer/grommet, followed by the retaining nut. Just how tight are these retaining nuts supposed to be????
The piece of rubber that sits between the tower and the washer grommet on the top of the tower appears to be worn away around its sides... ... ..... I assume this is from the nut not being torqued correctly????
With no instructions to be found on Bilsteins website nor anywhere else that I can find, I am shooting in the dark here.
HELP!
Thanks,
Rogue
HELP!
Thanks,
Rogue
