Need Clutch Info
Gettin' a new truck?
How do trailer lights work?
Ok I'm putting a 91 5. 9 with a rotory pump in a f350 crew cab with the I think getrage 5 speed,I plan on screwing with the pump and want to put a clutch in it that will hold up good, does any body make a good single disk clutch that will hold up good and not trash the flywheel and not cost as much as the engine(luke - stock dodge or what)????? I will be useing this truck to tow and a weekend screw around truck(pulling??????)
DEFINATELY call Peter @ SBC and talk to him. He will only sell you as much clutch as you need. Sounds like you need a South Bend 13" Con O (13" is upgrade for towing 8K or more) for no more than you are planning on doing.
You do NOT want to try sled pulling on a single disk clutch, you WILL destroy it! I learned first hand, 5 month old TST clutch said BYE BYE on the 3rd Low launch @ 2500RPM's..... never even smoked though?! :confused:
I'm going to be doing a SMALL amount of sled pulling next year, and my SBC Dual Disk goes in next weekend!! Oo.
jwilliams3 said:
What Mark really means is:
"I am going to be pulling SMALL sleds next year"
:-laf :-laf
You just can't leave well enough alone can ya bean pole?!
Like I said, I'll tend to you later! :rolleyes: :-laf
