I've searched every wording I can think of and cannot find the thread that has pictures showing the wire on the starter shorting out that draws down the batteries. My drain is back and I am looking at all the possibilities that have come up since the last time I thought I had it fixed.
I replaced the electric cooling fan clutch because I was getting a code for it. Drain went away for few months and came back.
I replaced the alternator because it tested bad. Was fine for a few months and came back.
Last time I removed every fuse, breaker and wire one at a time and didn't isolate it. My new list of possibles is:
The Starter short.
Another bad alternator.
Battery temperature sensor.
Bad voltage regulator in the ECU. :{
Instrument panel issue.
Any other suggestions I can add to my list? Is there any way to test the voltage regulator? This is kinda getting old.
The Starter short.
