I need help. Today, my Mallory 4150 took a dirt nap on me. I had the truck parked, at idle with the exhaust brake on while I strolled through the isles of the local hardware store. When I returned to the truck, I noticed my SPA FP gauge was reading -11, that's right, way below 0. My first thought was that the SPA electric sender was acting up due to the vibrations from the Cummins. I released the e-brake and let the truck cool down, then shut her off. I then bumped the starter, to check FP and found no reading from the SPA gauge (0) and the lift pump was dead quite. I figured that I blew a fuse(the Mallory is wired into the existing "hot line" that the original Carter lift pump was on) so I start checking both the interior and engine compartment power distribution centers to look for a lift or transfer pump fuse, but the only thing I could find was the relay (fuse?) under the hood, which I removed and replaced, after a short trip to my local D. C. dealer. After I installed the relay, I again bumped the starter, no FP psi's and no noise from the Mallory, when it now should be humming for about 20 seconds or so. I was able to get a test light from a friend that stopped by to assist, and I have power to the Mallory when I bump the starter. Not the end of the world, I figure. I'll just get the truck towed to my place of employment, order another lift pump and put it in, then all will be okay. I friend of mine responds with his tow truck, a flat bed as his conventional rig is down for repairs, and proceeds to put my baby huey on top of the flat bed, barely fit. As the truck is being winched up, my buddy, standing next to the flat bed as I am inside, steering it up, hears a loud noise and see's a flat black washer fly from the front of my truck and land underneath my truck. A closer inspection reveals that the tow operator placed his "hooks" inside the front universals, both left and right, and sheared off two of the "caps" that seal the universal bearings. I'm guessing that's what they are. I found one cap missing from the left universal and one from the right. Looks like they were pressed in, am I right ? My truck is now safely resting at my P. D. , awaiting a new lift pump, which I will next day order tomorrow. My only real question is whether the truck is safe to drive without the caps on the universal bearings. My buddy, the tow operator, promised to make good on any necessary repairs to the universals, but it's yet another headache to deal with in my already insane schedule this week. Does anyone have an idea on what the repair to my universals will cost and can I drive it safely to a shop in this condition ? I will replace the Mallory myself, and tear down the bad one to attempt to locate the cause of the problem. I figure that's the cost of being your own warranty station. I don't have the time/tools or where with all to repair the universals, so it's going to have to go to a shop to get them repaired. Any advice that an expert can give on the universals would be greatly appreciated. Sorry for the long post. Please help !!!! ... ---...
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,SPA fuel pressure and temp. gauge,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Lund bug shield,PM tractor utility back up lights,Penda bed mat,365. 8 HP on the dyno and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
Scott W.
