Jim. .
With respect to you and not trying to make this sound like I am questioning your tests I have a question or two for you.
My first one would be how you could even begin to make a comment about thier attention when its a well known fact that they have had many of their Dragon Flows come back for one problem or another. There have been enough of them sent back that I know of to know I would have never made that comment. The set of Dragon Flaws that I ended up with through a deal out here were still in the box,unopened and never installed. When installed in my truck they never ran right,popped and missed and killed the truck on the dyno for power. I had them sent out to a neutral shop to be checked and the popoffs were off 43% from one to six,and you say attention to detail. I wonder if your just being a cheerleader here for them.
Andy, if your or anyone else has had issues with the Dragon Flows I'm sorry, but that has nothing to do with me. To be very honest I called Brady after the last dyno event to talk to him about the results and told him that I would like to make a tiny change to the injectors, he agreed that it would work and I sent then to him after I swapped the 370's back in that I had sent to him while I was gone on my 33 day road trip (work) 4 of the 370's were bad, 2 he salvaged.
On that Dyno day trip I drove from OKC to Ft Worth, to Paris TX and back to OKC and still got 19 mpg using a 3% correction for 265 tires vise 245's.
The second one I have is what fuel pressure are you truely running at?. In one post you say maintain 45-50 with your A1000 and then later you say you are maintaining 100 with the regulator,which is it?. How long do you expect the pump cam to last at 100psi?. Man I love your smoke and mirrors games,you must have made that 640 on your "stock" 215 pump too.
You guys get alot of info from me but at times you fail to put it all together, there are things I talk about and there are things I don't talk about. Like the Dargon Flows I will not tell you'll what Brady tells me that he does on the inside.
There are actually a few thing on the fuel pressure. The last time I checked WOT pressure I was able to hold 45 psi or so with the aux on with no boost reference hooked up to the regulator. Since then and since the last dyno event I added another feed line to the pump and will try that on the dyno but it added 5 psi of boost and allot more fuel to burn.
The 100 psi of fuel pressure comment comes from being able to hook up a boost reference to the regulator, 50 psi of boost, 50 psi of initial fuel pressure gives you 100..... call it a guess, and the pump cam should be fine but the pump housing will errode, remember I run around at 35 psi using the stock system. At the last dyno event I ran no boost reference as I didn't feel like I needed it and I had allot of smoke, the next day I realized I had a tad too much plate in and backed it off 1mm and it ran or acted better this is with the Dragon Flows, with the 370's it likes that little bit more.
So I will cap off the fuel system now and give you even more info. 12AN suction to the A1000, 10AN line from there to the bigger FS1001 filter and housing (got it from Haisleys) then a 10AN line up to the pump were it goes into a 1/2" Y block. One 6AN line goes into the original Nipple fitting/Banjo bolt from Haisley's kit, the other 6AN line goes to the front of the pump to the inlet above the Rack Plug, that is an M18 x 1. 5 fitting to a 6AN. Then the overflow valve is removed and I use an M14 to 6AN banjo to the regulator and then tap into the stock return line.
Yes the 640 number was from my stock 215 pump, just like I have said before. Stock cam, p&b's, dv's, dv holders but has been to the bench before I bought it and I run a #6 TST plate.
Sorry for the late post, must have missed it.
Jim
