I need the expertise of this forum on a problem with my '96 I just bought. Some dummy tightened the oil drain plug to the 60 lbs/ft multiple times, without changing the plug etc. Now the plug has tapered flanges (no big deal, I plan to use Geno's upgrade) but the pan now matches the plug taper. I did the first oil change since I bought the truck, so when I put a new gasket on, and plug, torqued it to 40 lbs/ft. , guess what dripped. Not just an occasional drip, but it weeps slowly. Appears the sealing washer is only making contact around the very outer edge and nothing inbetween, so the area around the plug threads doesn't get compressed to seal. Short of replacing the pan, what can be done? I can't believe this is the only truck that has experienced this, so I'm counting on the wisdom of the membership to have a cure short of replacement. Thanks to all for any advice.
