Need to know acceleration #'s to check low performance
tc and tps continued
Bringing Daddy from the Dark side!
Whats the procedure to check the performance of a 6speed truck? I remember something about rolling at 40 in 5th then seeing how fast it could get to 60 but I'm not sure. I can't remember the numbers and can't find the post. #ad
I need to figure out why my 01 has lost 3 lbs of boost-
https://www.turbodieselregister.com/ubb//Forum4/HTML/004085.html
Help is always appreciated- Zach.
2001 black dually,4x4, 6 speed H. O. ,loaded up and then some!
Zack, my numbers don't compare to your setup (see sig), but last time I checked my 0-60 times were 5. 0 to 5. 5 seconds. That is rolling along at a steady 40mph in 5th and then tromping it. 0-60 times were 10. 0 to 10. 5 seconds. This is with RV injectors & misc. other mods, running 21 psi boost (no boost module).
I think Dave Fritz' site has D/C's Low Power specs but they are a little pathetic. . . your truck would have to be a sick stocker to flunk #ad
Vaughn
'01 2500, QC SB 2wd, ETH/DEE, RV injectors, SS fuel lines, lift pump relocated to tank, Amsoil air filter, straightpiped 3" exh. ,
Originally posted by Vaughn MacKenzie:
but last time I checked my 0-60 times were 5. 0 to 5. 5 seconds. ... ... ... 0-60 times were 10. 0 to 10. 5 seconds. This is with RV injectors & misc. other mods, running 21 psi boost (no boost module).
<font color=blue>Think ya mistyped a number there Vaughn, 0 to 60 in 5. 0 to 5. 5 seconds is a bit fast hehe. If it wasn;t a typo then um send me some of the fuel your using please #ad
Hey Dune,
I know you've checked your hoses and such already,but have you looked at the gaskets that go between the aluminum intake horn/manifold heater/intake manifold? Those have been known to have a tendancy of ripping or getting blown out.
The only other thing to do might be to take it to a diesel shop and have them pressureize the intake system to see if there is a leak.
-Mike
Prior to installing the VA, my truck did 50 to 75 mph in 6th gear in about 15 seconds. I have the 3. 54 rear; single not dually, and a little bit of load (camper shell, other toys in back). Also, RE-880 filter, but I doubt that really makes much difference time-wise.
Don't forget - maybe you've lost boost, but, the gauge could also be reading low. Keep that in mind if you don't find anything else.
2001 ETH, QC, LWB, 4WD, 3. 54, SPA Pyro & Boost, K&N RE-880 w/foam pre-cleaner, ARE Z-series Cab-high shell, Rear ARB locker, and all kinds of synthetic fluids...
Thanks Mike, thats something I have not checked yet. I'm going to test that and some other things today, if I can't come up with anything then it looks like I'll have to take it in.
My 0-60 times, stock, were in the 13 sec's.
After adding the power Edge 'EZ box' my times were consistantly 10. 5 to 12. 0 sec.
After adding the boost elbow that increased boost from 19 to 24 my 0-60 times went to 11 flat. But today, I did a run and it was 12. My truck felt slower all day. Does the ECM relearn something and reflash the ECM to stock?
Bob in Sacramento, Y2K Black 3500 ISB 4x4 4:10 LSD,Auto,QC,SLT Laramie, Slightly BOMBED :) LB, Polished Stull Billet Grill & Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges,Rancho 9000's set at '1',Diamond Plated Tool Box, OEM U. R. Bedliner + other stuff.
Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
