Had eye surgery last fall and thus couldn't drive (once the first eye recovers, have to do the same to the other eye)... tried to go out and start the truck when I could but would get to busy stretches with work and forget; I work full-time from home, and it's an apartment complex, so the dually is outside. In late February, I realized I hadn't gone out to start it in weeks, gave it a crank and got nothing. Called my roadside assistance, they came over and jumped it, and all seemed ok for a while - figured the cold air got to it, but nothing worse. In the meantime, decided to get a jump box, and after about 2 months, batteries wouldn't start. The box showed both batteries at about 10.8-11.0 volts. Again, worked for a while as long as I was diligent about getting out there and running it for 15-30 minutes. Last week, had to hit it with the box again, both batteries around 11. Enough is enough. My eye has recovered to a point where I'm comfortable driving locally but not yet on highways - and this would actually be my first venture out by myself in 8 months. Had to go anyway because a new eye drop prescription can't be delivered as it must be refrigerated, so I had to go pick it up. Across the street from my Walgreens is a fairly new Advance Auto Parts, and as they advertise, batteries are installed for free. So I went there and got two of their group 65 AGMs, 750 CCA ($199 each), 0-36 month full replacement, 37-84 month pro-rated. Old driver's side battery was swollen (not good), so it was a timely buy. Cummins fired instantly when they were in, and I'm a little more confident the AGMs will be ok as my driving time s-l-o-w-l-y increases back to normal.
By the way, that free battery installation at Advance... it's not just 'put it in and goodbye'. Cleaned the cable connections and used an appropriate amount of dielectric spray, cleaned and WD-40'd the mounting nuts as a couple had more than their share of rust, and for $3.49 each side, sold me the terminal kit which includes an O-ring for the positive terminal to keep it clean. They also connect a trickle charger under your dash to make sure you don't lose any of your electronics settings.
For the jump box, I got the NOCO GB150 4000 amp. Turns over the Cummins instantly and only weighs 8 pounds. Highly recommend it.
