NEW 2 LOW UNLOC KIT contest give away
We are please to release our New 2 Low unlock kit. We are going to give away 5 units to some lucky TDR forum members. Here is the deal.
You Must tow and you have to write a product review on how it works for you and the ease of installation and post it here. Post your user name, the year of your truck and the weight of your load. On Friday Morning I will take all the names put them in a hat and draw them randomly. I will post the winners Names Friday Morning and send them a PM for your shipping/mailing address. Yes its that simple.
Here are the highlights of the Product.
https://www.dieselperformance.com/sh...-2013-2016-586
Designed to allow the operator to manually disable the front wheel drive mechanism by holding the hubs in the free (2WD) mode with the transfer case in 4WD low range.
By allowing the front wheels to be disengaged, maximum torque is available to the rear wheels.
This will also allow for sharp "All The Way Over" turns without the front axle u-joint hopping or binding.
With this kit installed, the front wheels will NOT be driven through the transfer case.
Allows to have full power and torque while in a high gear reduction applied to the rear axle(s) only.
Installation is simple, the kit plugs in below the glove box.
No wire cutting or splicing and no wires through the firewall
Kit comes with an illuminated rocker switch for control and to indicate when the front axle is being overridden.__________________
