Engine/Transmission (1998.5 - 2002) New Dieseler
Engine/Transmission (1998.5 - 2002) 01 ram 3500 factory fuel pump
Engine/Transmission (1994 - 1998) 98 2500 diesel hard vibration
No issues, if folks mind they usually let you know...JK.. It's a lot to take in and some of our trucks have issues, trying to figure out a starting point isn't always the easiest thing to do.
Here are a few screen shots on how to adjust your signature.
I'm on my phone so it might be different on the computer.
1st when I reply there is that small box for show signature. That is always checked for me.
Then if I wanted to add stuff "This is a test" I did the following.
Hit the setting gear go down to edit signature a new window opens, it will show your current signature, then below you can modify that, if you want you can preview it, but you must "save signature it should update.
I know if I use my back button at times that brings me back to the blank entry, so try to use the link to go back to the forums.
The next thing you will want to try is uploading a photo, I have to use "go advanced" on my phone then there is a small paper and paper clip icon in the upper left above where you enter the text, that opens up a new window where you can attach items. It takes a bit to upload stuff and they will disappear from the upload list and go down A bit and you will see them, then "close window " .
If on a real computer all you need to do is select the picture frame from the normal post, again when you select a photo it takes a bit to upload and it will add a odd script into your message, that is the photo, I think you can delete that and the photo is still attached.
Folks can unsubscribe to anythread if they get annoyed by the number of responses, emails, tone of responses, since you are the OP (original post) I'm always under the impression you can do what you want with your thread, if you get off topic on other threads and you are not the OP folks might get annoyed and try to keep on topic. It makes it really hard to find stuff or help when the post and signature are not even close to what they say they are for.
Signature and how to get photos are some of the big things, then search for your issues first and see what types of existing posts there are already out there.
Thanks for the details I am new to the Diesel world myself just inherited 2001- 3500 Dually with 76.000 original miles any other suggestions I will get the gauge set ordered
Bob, an 01 with only 76k!!!! What a gem! I'd change all fluids, in addition to things I mentioned above, and use high quality fluids. Stick with fleetguard filters you can order at Geno's. I'd stay away from Fram as there were problems with filter media breaking down and ruining the engine on Cummins, but that was a while ago.... Better safe than sorry. From there drive and enjoy and maintain.
