Well I think it is a new theory, since I can't remember reading about this idea.
Have you ever wondered why Dodge made the factory exhaust start at 3" going into the resonator then expand to 4" inside the resonator, exit at 4"to the 4" inlet of the muffler, then exit the muffler at 3" then stay 3" over the rear axle to the 4" tailpipe tip??
It aways seemed like a lot of changes in diameters, clamp and hanger sizes with no apparent reason. .
Well I believe that it is done to reduce or eliminate our drone we get most of the time with straight 4" exhaust systems.
My 'theory' is that the exhaust pulses from the engine, even when 'cut-up' by the turbo wheel have a certain frequency, or spacing as they travel down a constant diameter pipe. The intensity of the pulses change as we add more power at a give rpm, but the frequency of the pulses stay 'in tune' with the engine rpm.
So if the pulses go into an expanding chamber then something has to happen to the frequency or the amplitude [intensity] of the pulses. I'm not sure if they speed up or slow down, it really doesn't matter for this theory. What happens [I think] is that once the expansion chamber ends and the diameter if the chamber is reduced again to the original diameter, the pulses can't reorganize to the steady frequency that they had as they entered the expansion chamber. This disrupts the pulses and reduces or eliminates the drone.
When we eliminate the factory muffler and go with 4" from the resonator back the pulses have to change as they go into the larger pipe diameter, but there is no point where they are reduced back to 3". Or with a full 4" system the pulses just travel the whole length of the pipe and set the pipe itself resonating with the exhaust frequency.
Well I have just finished about the 15th modification to my exhaust system since I got rid of the factory muffler in the pursuit of power. I have always [with one exception] had some resonance drone in my exhaust. I could move the rpm of the drone around with various different pipe wall thicknesses, muffler changes, arrangements hangers etc,etc. But I could never eliminate the drone.
The other day I tried putting my Walker bullet muffler at the very beginning of the exhaust system, right at the end of the downpipe. It was previously under the bed prior to the axle My idea was that if I could slightly muffle the exhaust as soon as possible just as it starts to go under the cab floor it could only help with reducing noise and drone. Well it was a COMPLETE failure, in fact I had a LOT more drone from the rear portion of the exhaust. The whole truck bed was droning.
My exhaust system is a 4" downpipe, to which I have added a second layer of pipe to to make it double walled, and then wrapped it with header wrap. Then the [wrapped] Walker bullet, followed by about 20" of 1/8" walled 4" exhaust pipe, [wrapped] then a 24" Allied straight through muffler, [also wrapped] then about 50 or so inches of 1/8" wall exhaust pipe [wrapped] clamped to the 4" tailpipe that goes over the rear axle. The bed of the truck and the cab just hummed with drone between 15-1900 rpm under any load. get up to 2000 rpm, and virtual silence.
In one of my previous systems when I had a lot less power, I had installed as an experiment a chamber I had found on a semi-truck stack. This chamber was about 14" long, 8" in diameter, and had 3. 5" inlet and outlet and a baffle in the middle of the chamber. I cut the baffle out with a long airchisel making it just an open chamber. When I had this in the exhaust just before the tailpipe went over the rear axle, I had no drone in the system. I removed this chamber in the belief that it was restrictive when I added more power.
This morning after making a parts-run, and in agony from the new found drone from the muffler rearrangement the day before, I decided to try the chamber idea again.
I have had a straight through 5" muffler, 20" long, 9" diameter in the shop for a few months, and decided to splice it into the system after the two existing mufflers, before the tailpipe went over the rear axle. The same factory-like expand-then-reduce idea.
Well it works!! Very well in fact. There is NO DRONE from 1500-2000 rpm, even under heavy load. I can hear the engine working as I add more throttle, but the sound is from the engine not the exhaust. It is possible that adding the mass to this portion of the exhaust system helped reduce drone, but I removed 4" 1/8th " walled pipe for only 24" or so to splice in the 5" muffler.
So if anyone has the dreaded drone and hasn't been able to eliminate it with the angle iron clamped on, different resonators, moving mufflers or other methods we have all read and posted about and tried, this might, just maybe be the fix we have been looking for.
Greg L. The Noise Nazi
