Hello
I am looking at what I believe would be called a 98. 5 2500 2wd manual club cab short bed with 90k miles. I am not sure the 24 vs 12 valve is an advantage after some things I have read. What do I need to zero in on when looking over a service record and the truck itself?
1. I have read lift pumps can be an issue but upgraded factory parts are available? Any other mechanical issues to look for/ ask about?
2. Do they have unit bearing front end or the traditional bearing in hub of old?
3. I hear they have a hybrid Dana 70/80 rear consisting of a Dana 80 center section stuff and 70 axles? They are all full floaters?
4. I will probably spend at least the first year evaluating the vehicle, starting to tow race car etc. around 6K lbs. It seem the Cummins is the best to mod in the result/dollar category? Does this apply to the 24 as well as the 12? In a nutshell what should it cost me to do exhaust, turbo, injectors, misc air intake etc. to get me say 300 hp and 600-700 lb ft with an early 24 valve? I guess a chip comes into play as well. I hear the 5 spd shifts better, but have looked at the numbers and it appears quite a bit weaker than the 5600 and ZF6 etc. How much quieter if any are the 24s vs 12s? Can the 24s be manipulated to change sound levels with changes in programming? How well can the factory engine respond to a chip alone?
5. I like fuel mileage as well, and have heard nothing beats the Cummins with a manual. 20-25 mpg cruising? Anyone run an over drive or higher rear and get the rpm below 1500 at 60 mph for cruising? Further mileage gains?
Anything you can offer is much appreciated.
Chris
Chris
