I assume you've triple checked that you have all the wiring harnesses plugged back in.
you didnt break the map sensor when pulling the head out or back in did you? again, just checking.
I would visit each sensor and connector unplug> grease> reconnect. trace the route of each too make sure they arent smashed or had been smashed in the RR.
check that you didnt smash the harness going across the cowl. most of the wires in that bundle go to the PCM. again, plug and unplug those two connectors.
