Well, my factory lift pump went out on "Red" last Friday. I ordered an Air Dog II and installed it last night. Got all the air out of the system this morning and got it running. The engine is running very strong, but sounds very different than before, sounds about like an old 12 valver that needs the valves adjusted, or like an old 7. 3 out of a Ford. The check engine light is on too, and shows P0088 as the DTC, which means high rail pressure. A friend of mine said this is probably due to a bad fuel control actuator on the injection pump.
I would like to know if a bad FCA would cause the excessive engine noise and the P0088 DTC? Has anyone else had this problem?
Thanks in advance.
Thanks in advance.
