I understand. I am contemplating feeding it dose of injector cleaning solution. I can do this very easy by pouring it in thru the DAVCO unit, with the top open, it will not suck from the tank, only from the clear plastic top. The owner seemed "unusually knowedgeable" of fuel contamination for an old office guy that never owned a diesel before, but then again it was starting and running perfectly when I bought it. . Nothing to lose, and it it tends to loosen things up a bit I will know I am on the right track. For anyone following this thread and enjoys the challenge as much as I do, here is a very long version of events from day one:
The history I think is a clue. This motorhome had been not in daily use for the last 4-5 years, but was hooked up, inside a lean to, and periodically run. Fuel was always treated with biocide (hey, I had bug problems in diesel, not fun at all).
I had only a short time, so went and looked at it, drove it, slept in it ovenight, and bought it. It had its minor problems, but started easily every time (even with shot batteries), we started it at least a half dozen times in that visit. I gave him a check, and headed out to Florida for a few weeks, when I got back, went back to his place, we again started it a half dozen times, even with shot batteries it lit off quickly and did never smoke, knock, balk, hesitate or anything other than first class diesel Cummins. Oh yeah, the fuel tank was full, he always kept it that way to avoid condensation. He and I were well aware of diesel picking up a load of water when sitting, San Antonio is somewhat moist of course, actually Canyon Lake, West of New Braunfels.
The trip home went nicely for about I would say 50 miles. i stopped for a cup of coffee at a circle K, let the turbo cool a minute, and shut her down. No concerns about starting, hey, it ALWAYS started easily. Coffee in the gut, and back on the road, but she would NOT fire, crank and crank. I called my emergency roadside service, I did not have a single tool with me. Waited and waited as usual, thought about it and went back in the circle K and got a can of WD 40 and a can of starting fluid to experiment. It fired right up with a shot of WD 40! Vowing not to shut it down again until I got home, headed out again. Wanted a snack or something maybe 30 miles down the road, and it died while I was turning off into another Circle K. Let it roll into a parking position, called again for service. Waited and guy came out with a VW and jumper cables. He hooked the single generator battery to the bank of 5 starting batteries, I told him of course that that was a useless drill. The damned thing started! On the road again, and somewhere between Corpus and Kingsville Texas, as I was rolling to a stop light, it died again, right in the intersection. A passing tow truck pulled me out of the intersection for a few bucks, I used either starting fluid or WD40, it started up and ran fine, I am now about a hundred miles from home, wasted most of the day. Thinking that PERHAPS the voltage was too low to keep the stop solenoid up, I started the genset and let it run the rest of the way home. It never quit again during that time, the sun had gone down and it was cooler also. At home, it seemed to start ok, maybe a bit lazy but the batteries were shot too. I put in a fresh set of 5 from Sams, almost seemed to have solved the problem. Several more starts, getting worse each time, I decided to get it on the road and go get some fresh fuel. New circle K truck stop would guarantee me fresh fuel so there I went. Full of fuel it seemed to start even worse (had to use starting fluid to get out of the service station), just progressing more and more towards a no start situation. I put it in storage, then found I could not even start it. I found the non operational lift pump, put on the DAVCO, new secondary filters, and new lift pump, bled it and it busted fairly well, far from instantly. Restarted it a half dozen times, thought the problem was maybe solved, but still not happy with the amount of cranking to make it start, probably 4 revolutions or more to start, when hot. As I started worrying more about it not wanting to start, it has gotten to a no start situation. Even took out the new batteries and fully charged them, all five.
When I give it a whiff of starting fluid, it starts well, runs instantly smooth, no smoke. In fact, no smoke ever, pulling, cranking, upon startup, It does seem to be putting out excess stink, eyes burning, coughing, etc after a small run time, but then again, it is in a garage, the exhaust towards the open end.
