I've started getting a noise in either the clutch or trans. When I let the clutch out in neutral while stopped, it sounds like a fairly loud rattle. If I push the clutch in, it stops after the trans quits turning. Cruising around, I can hear the noise, but if I push in the clutch while I'm still rolling, it also stops.
I let the dealer listen to it and he said that its for sure the throw out bearing and that I should leave it alone until it gets worse. That sounds backwards to me. If it was the throw out bearing, wouldn't it make the noise with the clutch disengaged? I'm wondering if it isn't more likely the trans.
Thanks for any suggestions
