Dave,my pump cant be heard while the engine is running unless your laying under the truck. When i was mounting mine,I used some left over sway bar end link bushing kits i had at the shop,I opend the holes up in the frame,so the bolts didnt touch metal anywhere,the step in the bushing slipped right in the hole,I used a bushing,and the big washer inside the frame,and another between the frame,and pump bracket,then tightened the wholee thing together,its sturdy,yet totallt isolated,so no vibration can be directly transmitted to the rame rail. It seems to work great,and i think the bolts need to be isolated too,not just the pump,so this does both in one shot. Youll need some long 5/16 bolts,and lock nuts,but its well worth it,IMO. I can get my pressure down to 3 psi,on level 5 on the comp. It used to go to zero on level 3, Redneck, if you pulled out your pusher,what are you running now to get 5 psi?Id like to know. I was wondering if just relocating my stock pump would give me the same pressures as this 2 pump combo.
