Just got back from a total of 650 mile trip towing trailer and clutch works great and is still quiet, haven't heard any gear rollover noise yet, Only thing i can tell is different from oem is that it doesn't slip and is a little harder to push the clutch pedal in, I'm satisfied, MonteIt was quiet, the clutch was slipping when in regen due to surge.
Yeah, but it is harder than the original to push in, hope they bled it right,MonteGlad to hear it, did you install the upgraded clutch master cylinder kit?
Mine's somewhat harder due to the 3250# pressure plate and I have the upgraded HD's. Not bad at all though. Monte,what fluid are you using now?Yeah, but it is harder than the original to push in, hope they bled it right,Monte
No, no knockA little of the subject guys, but did any of you hear a slight knock in your trans/clutch before DMF replacement? Mine will knock a little in neutral with the clutch engaged. Push the clutch in, the noise goes away... That's not the rollover noise you are describing is it?
I've still got the Amsoil ATF in mine, just got back from disaster deployment and haven't had time to change it out yet, and weather turned sour, will update when i change fluids, MonteMine's somewhat harder due to the 3250# pressure plate and I have the upgraded HD's. Not bad at all though. Monte,what fluid are you using now?
No, no knock
Thanks. Trans is smooth with no noise under power. No clutch slip, just that sound at idle. I know I need to do the clutch eventually (~72K) but the noise has me wondering what's going on in there.
That is the DMF telling you it's about to retire.
my DMF went 124,000 miles, and looking at the clutch after pulling it, the disc wasn't very bad, The dmf had some springs broke and you could see it had been slipping, You'll be better off with it replaced, i can sure tell the difference, especially while towing, you hit a hill and give it some juice and NO slipping at all ,just hope i can get another 124K out of this one, Dodge dealer sent me a card wanting to give me 28,000.00 trade in for my truck, think i'll keep it.Thanks. Trans is smooth with no noise under power. No clutch slip, just that sound at idle. I know I need to do the clutch eventually (~72K) but the noise has me wondering what's going on in there.
The roll over noise mine has is the same as my NV5600 had but that was at idle in gear rolling through a parking lot in second. My G56 has it below 1500 rpm in 3rd through higher gears, although I rarely go that low of RPM in sixth. On a weird side of the rollover noise, not to confuse the noisy trans at idle, it is a lot quieter when in regen.
