Engine/Transmission (1994 - 1998) New transmission now driveline vibration
Engine/Transmission (1998.5 - 2002) Power upgrade
Engine/Transmission (1994 - 1998) Collapsed hose- What is it
Driveline shakes like hell under acceleration, the more the worse. From about 25-40 mph. No matter what gear. New aftermarket auto.
Clears up after 40-max speed. No shake at all there. Also none below 20.
Pulling driveshaft next.
Any any other ideas?
EDIT
I just remembered that there were some washers left out on reassembly. Maybe they were under the carrier bearing?
FOUND IT! fixed it.
Stoopid---DOH!
As I was preparing to pull drive shaft, I did some pulling and yanking and YIKES:eek: the transfer case was about to fall off. :rolleyes:
:eek: :eek: :eek:
Now ON WITH THE BOMBing!!!Oo. Oo.
Wade. . if ya didn't already do it. . better check the splines and seals on the transfer case... loose = wobble = dammage
better safe than sorry with roadside exploded unit
If all else fails you might want to spin the torque converter 180 degrees on the flexplate. Stacked tolerances can sometimes cause an imbalance. Rebuilt a new Chevy 1-ton and had that exast problem recently. Don't see it often though.
Joe
