I recently added a Isspro pyro. I had the 607 long thermocupling and noticed it's touching the bottom of the exhaust manifold. I pulled it last night and probably try to find a shorter one. I can't reuse this one cause it has a rough place on the tip where it was rubbing, can I? I know I'm lucky - the turbo is still in one piece. Any suggestions? Also there is a small leak around the brass fitting in the manifold. I'm already 4 turns into the manifold and don't want to tighten anymore. Any suggestions with this one? Will a little leak hurt? Thanks in advance.
