Hi Guys
Hoping someone can help me out here.
This happened to me about a month ago and lasted for only two days then went away.
I have been driving the truck problem free for the last month.
3 days ago the gremlin cam back.
No power at all. No Boost registering on the gauge. When the the problem came up it just happened. I shut of the truck it was running fine. I started it back up no power or boost at all.
Air cleaner is good and clean. I even took off the air inlet tube and went around the block.
I tried pincihing the air line on the turbo with vise grips, the line I would imagine goes to the BOV. I know on the 12 valves you could pinch this and raise boost. No change at all.
I do have an edge installed with out the injector pump wire tapped. Turning this on or off has no effect either way. Unplugging it also has no effect.
There is a full exhaust installed on the truck and the resinator has been removed.
The turbo does have a little play in the shaft. But it does not seem to be too bad. it spins freely by hand and whisles pretty good just reving it up in the driveway. But under load there is no increase in boost.
Everything else is stock. The truck has 150k on it. It is a 1999 6sp manual 4x4.
Thats all I can think of. Your help is appreciated.
I thnking maybe a BOV, or the Turbo. Seems odd how it just came and went and now its back.
Thanks Rob
Thanks Rob
