Did more troubleshooting today and was able to determine that I'm not getting 12v to the headlight switch. I traced the feed wire down to the big connection plug behind clutch pedal. I used my ohmmeter and it makes a complete circuit from the large connection plug up the headlight switch. I don't have 12v coming in to big plug. So I would say next step is to pull apart PDC? I tried messing around with fuse 19 or fuse F on my box for parking lights and everything seems good with the socket/fuse.
Sample of where you may have to go next. Not the exact same unit.
Problem solved!!! Corroded wire was the cause. Looks like it had a test light probe hole in it and good old road salt took care of the rest. The only thing I can think of is I had a guy install an aftermarket alarm and he probably probed that wire with a test light. That was done right after I purchased the truck. Took almost 18 years to fail.
Can't say thanks enough. This club always amazes me with how helpful everyone is.
Thanks for the help!
That's great news. And the fix was relatively simple. I am a probe-o-phobe when it comes to wiring just for that very reason. IF I have to probe I'll use a sewing pin so it leaves a small hole, then dab some RTV on the pokes-n-holes, or seal with tape. But that's ultra rare in my "testing toolbox".Problem solved!!! Corroded wire was the cause. Looks like it had a test light probe hole in it and good old road salt took care of the rest. The only thing I can think of is I had a guy install an aftermarket alarm and he probably probed that wire with a test light. That was done right after I purchased the truck. Took almost 18 years to fail.
