Fuel supply pressure - stock truck with stock, properly working pump should put out 12-14psi at idle. Any less than 10psi, replace the pump. Never less than 6psi WOT for reliability. A good part of the fuel sent to the pump is used as lubrication and cooling, and returned to the tank, so you need more than enough.
As HP increases, the fuel system becomes a liming factor. We found that at 350rwhp, the stock fuel lines and banjo fittings were the first restriction. Changing to full size AN style fittings and 3/8" line would typically increase VP inlet pressure by 6psi WOT at 350rwhp.
Once that's done, the stock lift pump runs out of capability to maintain 6psi WOT at around 425rwhp. Adding a Carter P4600HP pump (rated 7psi) to the system would yield 18-22psi at idle, no less than 10psi at WOT at 500+hp.
A stock truck should make and register 18-19psi at WOT, full boost, on a scan tool. Snap On MT2500 series should read that no problem. Look at MAP voltage and boost psi. Holding different throttle positions should allow you to see all the numbers in boost pressure from 0-18/19psi, not jerky jumps.
Do you have a boost gauge in the truck? How much boost does it really make on a gauge? How many miles on the truck? Did you fix that boost leak under the heater grid element? Any codes come up on the scanner?
