Three days ago I changed the clock forward one hour. Two days ago, I noticed that the clock was off by 2. 5 hours when I went to lunch. Last night I installed a set of KC lights, and on my first trip out I had no speedometer, parking brake light and ABS light's are on.
I went out this morning and noticed one of the nuts on the positive battery post wasn't tight, so fixed that. No difference. I ran the actuator test, but didn't receive any numbers like I've seen posted elsewhere. I received the following:
C-CODE
21 18
A4 38
A7 67
AA 67
AC 00
00 00
The lights are on a simple rocker switch setup with a relay, not run with the headlights in any way (the KC's are located in my rear bumper). We're grounded to the negative post of the battery and we're drawing power straight from the battery as well. I don't see how adding the lights would make this happen, but I don't believe in coincidences. I'll go see if I'm getting any error codes and post what I find as well. Any help appreciated.
C-CODE
21 18
A4 38
A7 67
AA 67
AC 00
00 00
