Engine/Transmission (1998.5 - 2002) No start
'02 5. 9 auto. I do not have ground to the crank relay. Think it comes from the PCM, #2 connector. Anyone know the wire color?
Thanks
The wire from ign. switch (through clutch pedal position switch if it's std) to relay is 14 ga. yellow with red stripe. Wire out of relay is 22 ga. black with white stripe. bg
Thanks BG. I've already looked at those. The one I am needing to look at is the one from the PCM to relay ground.
