I am replacing the ignition switch and the headlight switch and I am going to install the trailer wiring harness. I figured that since I am going to be putting in alot of relays anyway, I might as well go ahead and replace the prone-to-strand-you parts. That way I will have peace of mind(and I won't burn my knee on the steering column cover again).
I was going to do it last night, but a buddy told me about a poker game, and guess what I chose to do?
I figure that if I run an 8 gauge wire from the battery to the fuse block and use the key on from the ig switch just as a trigger for a relay in the 8 ga wire, I will remove almost all load from the ig switch. And basically I can use the original wire to anything as a relay trigger and run new wire into existing circuits and make everything work better. I will be doing the headlight relay mod and finishing the blower relay mod this weekend also.
