This problem has become so baffling my most reliable mechanic is finally advising I try switching my license plate because we've swapped just about everything else. My Cummins has always run hot with frequent overheating. I ditched the stock engine fan and clutch for a custom fan and Horton electromagnetic fan clutch. This fan setup moves a ton of air, tons of noise, blows dust clouds below the truck and will blow your hat off with the hood open. I also have a pusher fan in front of the intercooler working at the same time.
After overheating to the point of running out of coolant due to another sticking thermostat that boiled almost all of my coolant out and having to be towed I decided to take a drastic step. I pulled the thermostat and cut out all but the metal bridge in the middle. No longer anything opening or closing, just a constant flow with a slight restriction. This is a 180 degree Cummins thermostat from NAPA. Looked just like the one from Auto Zone it replaced, that stuck shut as well. Before that I'd been through a few original style Cummins thermostats with rubber sleeves that crumpled. The last of those stuck open in the winter and I couldn't get up to 50 degrees.
Removing the main restrictions from this thermostat has disappointingly done nothing to help. I'm grossing about 23,000 lbs on my way to Alaska. But even when empty I still get well over 200 degrees even at interstate speeds. What is odd to me is that my coolant got as high as 228 degrees today while towing up a mountain but didn't boil out. Took several minutes after cresting and going downhill to get back to the low 190 degree range. It usually boils around 210.
The radiator is only a couple years old. Been through a few thermostats before and after replacing the radiator. Can't run air conditioning because that seems to make the engine run hotter. I'm running the purple FLEET coolant from NAPA for big trucks with tap water. Running a higher ratio of water this time and that is the only thing I can think of that has kept my coolant from boiling over this time.
The head is my second replacement within just a couple months. When holding a hand over the coolant reservoir and revving the engine, there is no pressure from the coolant so I don't think my head could be cracked again or leaking through the head gasket, no injection compression or engine oil in the coolant.
The only thing I haven't replaced in a few years is the water pump. Does a water pump slowly go bad and allow overheating or does it just lock up and quit all at once? Do I need to look for a Cummins or Dodge dealer or will I be OK trying one from a parts store? I plan to try to find a shop in Bozeman, MT in the morning to put in a new water pump, assuming I can find one in town.
I should add that the truck usually runs a little cooler at night, but still frequently exceeds 205 degrees even when ambient temperatures are in the 40s. Under hot sun in the 90s we can't even run the a/c and keep temps down into the 90s. But at times even with my thermostat gutted we can't keep coolant temps under 210 climbing up a mountain with both fans on but if I keep the fans on for a long time during the downhill side the fans will sometimes bring the coolant down into the 160 something degree range. Takes a long downhill to get that cool. Thoughts? I've got a lot more towing to do and sure would like to have this problem solved unless it is fine and normal for my engine to not be able to stay under 230 degrees.
