This is for my wifes 98 Jeep Grand Cherokee 4x4 (we just bought it used 5000 mi. ago):
While I was checking the front brake pads today, I noticed when I turned the rotors by hand, the front drive shaft was turning. I then drove it around and tried to get the transfer case to disengage, but no luck (its got "select-trac" which is: "2wd, 4part-time, 4full-time, N, and 4lo). I
figured something was sticking to cause this, either from the transfer case end, or the front diff. end. So I pulled the front diff. plug to check the oil just to check it (even knowing it had just been changed). I found serious silver (metal) shaving gook on the plug about 1/4" thick, and could feel little or no oil with my finger.
Here's the kicker. Just about 6 weeks ago I had taken it to the Kwik oil change place and had them change the front and rear diff. fluids (since it was a used vehicle with 80K).
Symptoms: Lately the mileage has been terrible, and the front end has been making a lot of noise. I start thinking "crap, this things been stuck in 4x4 (possibly "4part-time", which is just below 2wd where the lever always is while driving) maybe for several weeks. "
Could it be the transfer case is stuck causing excessive wear in the front diff. Or did the oil change guys screw something up like not putting in enough, or the wrong oil, and the thing is binding up in the front? What are the possible problems that could cause this? If it's the Kwik oil change co. 's fault, how can I prove it?
TIA
TIA
