FDavid said:When I got home I applied some dielectric grease or whatever its called and havn't had a problem since.
LesStallings said:Did you actually put the dielectric grease inside the connectors or just around the plastic, sealing them as they slip/clip together?
Saccowboy said:hey guys i just finished installing the tst last night and boy does it run good. only problem i seem to have is i have a check engine light and i think 3 codes is that normal????
thanks for the help
Will
strokerschmoker said:Maybe It a SO thing. Mine Always has the P0336 and P0606 on the computer and i think it has or had the cooling fan speed error as well. Mine doesnt ever run any different whether the CEL is on or not. The only way my light comes on is if it cold out and I'm lugging the truck in too big of gear, sometimes the truck will miss/studder and on the third time it kicks the light on. After a few starts the light goes off.
JTryles said:Will, I notice that your sig says you had the Banks. Did you replace it with the TST box? What are your impressions between the two so far?
Goodys1ton said:Saccowboy,
I notice yours is an SO also, I wonder if the the program has something to do with conflicting programs in our trucks.
Goodys1ton said:A while back I had called TST and spoke to Mark. He has said he looks at the websites we post on and has never seen where people have found the p0336 and p0606.
