Normal Oil Consumption
stiffer "go" pedal?
Are pistons aluminum
Ok - don't yell - but I change my oil every 5,000 miles - very easy to remember. I tow only a very light boat - use the good strat filter - cummins blue oil - have 49,000 miles in 11 months. Now - what should one expect in oil consumption, i. e. a quart in 5,000 miles - a 1/2 qt or what do you think. It has to use some - heck the breather where it blows by uses a little.
If I lose any it would be unmeasuable. I have 80,000 on it. I also change oil at 5,000 intervals and I tow 6- 12,000 about 300 miles a month in the mountains.
97 2500 club cab 4x4,5spd,US Gear Overdrive, 3:55 LSD
Ditto E-9. I can't see where the oil has dropped in 5000 miles. I have 44,000 on mine, very little towing, but occaisionally hauling 3000 lbs in the bed.
Ray
01 QC LWB 5 spd, trailer tow pkg, camper pkg
VA, PS boost module and elbow, PS heater saver
I have 80K on my truck, use Mobile Delvac, change about every 12K-15K. I have towed my 13000 lb 5th wheel about 6000 miles in the last 2 months and havn't had to add any oil. It shows down about 1/4 in on the dipstick. Pretty amazing.
Tom
Tom W in Austin Tx 98 24v 2500 Quadcab, auto, 3. 54, lsd, Rhino, white/driftwood, Banks Stinger Plus, 275 injectors, Manix grill, nerf bars , DTT's TC, valvebody, cooler, Smartbox, Mag-hytec trans & diff, Pac brake, Bilsteins, dual Walker mufflers, Roadmaster suspension.
Amsoil. Zero drop. 44,000 miles.
1999 2500 4x4, auto, 3. 54 LSD, HD241, Quad cab SLT, Blk Sport Pkg, 16x8 Eagles, 285 Bridgestone AT, Bilsteins, SS ladder bars, 100% Amsoil, 80/100w lights, Valentine One, DTT TC/vb, Mag-Hytek trans pan, DD2's, DD TTPM, Isspro gauges.
1992 SC400
1978 Mooney 201 IFR
I have 168K on mine and no observable oil drop between changes at 5K miles. It gets black a little faster, but that's the only difference from when it was new. Actually, it runs better now than it ever did. Finally getting broke in I guess.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,DTT TC/VB,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver, KDP 160,000-NM-WT Insurance
MIne always used about 2 qts in 7500 miles, to about 70,000 miles. Now it does not use a drop.
I ran Rotella 15W-40 for the first 36,000, then switched to Amsoil 5W-30
My 3 Cummins before this one would use 1 qt in 6000 miles, no synthetics, always Premium Blue or Rotella.
Gene
[This message has been edited by MGM (edited 06-01-2001). ]
I have 168K on mine and no observable oil drop between changes at 5K miles... Actually, it runs better now than it ever did. Finally getting broke in I guess.
All right, Joe! That's the stuff I like to hear; this is why I chose the Cummins over the competition. I'm only up to 40k now, but, that's not too shabby since I only bought it last June. And it's getting better mpg and lower wear rates now than at 20k. Like others, if I'm getting any drop at all between filter changes (7. 5k), it's less than a quart and really not observable on that way-long dipstick.
2001 ETH, QC, LWB, 4WD, 3. 54, SPA Pyro & Boost, K&N RE-880 w/foam pre-cleaner, ARE Z-series Cab-high shell, Rear ARB locker, and all kinds of synthetic fluids...
Change every 5000-7000 miles, depending on highway vs. local driving habits. NO noticible oil consumption, 24,000 miles.
Greg
Y2K Dodge Cummins QC 2500 SLT Laramie 4x4 Long Bed, 4. 10/Auto, Forest Green/Driftwood, 265x75R16 Michelin LTX, 6 speaker CD, Camper/Tow/Plow Packages, Westin Black Nerfs, Mopar bedliner, Ultra bright diamondplate toolbox, K&N Filtercharger, Autometer Ultralite EGT and Boost gauges in 2-gauge pillar w/tweeter, DD Stage II injectors, boost module, and boost elbow. Yee haw!
http://www.rints.com/hammond for photos!
HC,
There was a post on here last year by a guy with a FL60 with one of these engines. He had 380K or so on it and he decided to pull the head to take a look. He could still see the hone marks on the cylinder walls so he just buttoned it back up again without messing with it.
BTW: Once in a while I'm in your neck of the woods. I think I'm related to all the old families in Yell Co. , especially around Mount George and Ola.
In 1800 miles I added 1 quart. Valvoline PB is in the truck now, and 25% of the 1800 miles was towing light loads. The truck has 80 some thousand on it right now. The previous owner always used Rotella T.
I'd like to add that if I were going by the marks on the dipstick alone I was in the middle of the safe range, which is obviously 1 quart low. I think it's odd that the safe range on the stick is a difference between having 9 quarts in there or 11 quarts.
The question I have now, is those of you that said you didn't burn oil, are you saying that the oil mark on the stick was still in the safe range (and you didn't need to add oil), or are you saying that the oil was at the full mark when you dumped it?
Just wondering because I thought a quart per 1800 miles was a bit much, but after another 1000 miles it isn't down at all #ad
So far my truck has not used enough oil between changes to show on the dipstick. I change my oil every 4,000 because of a lot of short trips where the truck doesn't have a chance of warming up. I have 17,000 miles on it so far. My dad has a '94 and his truck has never used oil from day one either.
Edit: Forgot to mention that we both are running Delo 400
'01 2500 QC SB 4x4 ETH/DEE 3. 54LSD
[This message has been edited by jdkenyon (edited 06-01-2001). ]
When I said no observable I meant that it didn't show on the dip stick. Obviously, it uses some oil because of the blowby tube mess.
Using AMSOIL 15W40 and tow 7000lbs once a month. If I pull hard I might use a 1/2 qt every 5K but that would be the upper limit. Unloaded virtually no comsuption.
32k on engine,
My engine has used less than 1/2 pint in the last 2 -5k mi changes with over 8k of that towing using Delvac 1300 Super 15-40. Prior to using Mobile the Valvoline would run through at a quart to quart and a half in 5k. Looking for oil ratings as looking into Dello 400 if other ratings of said concur w/ LE's rating of Dello 400.
