Use Oil Analysis (UOA) Results -- Should I be worried?
Important Emissions Recall
Recall for grid heater replacement
@Diesel85, On your truck, The test with the TBN is worth doing. It will tell you if you're oil would last longer. Not that you would want to run longer on an oil change but will tell you that the oil is still doing it's job. Either way, keeping an eye on things is a great thing to do!
I really don't see the point in test without TBN.
That's why I want the he higher $16.21 priced kits which include the oils TBN report. Hopefully @06 Dodge will reply back on how to get those pesky test kits.
I see Cummins is out of stock so use their link to have them email you when they are back in stock, but if you need one asap then you will need to spend a few extra $$ and go here order Fleetguard kit CC2543 : https://www.genosgarage.com/product/fleetguard-oil-analysis-kit-cc2543/oil-filters
What I like to do is put all of my info on a separate sheet of paper, for me its to darn hard to write info on the small area they give you with your kit, also don't forget before you send in your sample you must email customer service to set up an online account ( fyi it may take a few days to get a reply so do this before you get your oil sample) once you get that number you go online and input info on each vehicle you will plan to do UOAs on and also give each one a name that you will use for when you send in your oil samples.
