Is the Hobbs pressure switch adjustable? Also can you adjust the cutout pressure? Part number? What happens when your foot is off the throttle going down hill having only a front trans pump without a rear pump to supply 48psi?
Having a 727 and not a 518, what controls the kick down on a normal 518?
Governor pressure should be pretty steady on a RH unit so shift should be fairly predictable. Gov pressure is speed dependent and the pressure is a function of rpm to the input shaft for pressure. Even though you lift the pressure should ramp down with the speed.
The one caveat to this system is if you mod the VB the wrong way it will try to shift to OD in 1st and 2nd. May be good or bad depending on what one is trying to accomplish.
Here is the cute little bugger that will do the job:
