not enough a/c with 08 mega-cab
harsh ac clutch engagement
HVAC problems.
hot days with lots of glass, a/c can't keep up.
somewhere there was a post of installing a bypass hose and valve for the heater. can the hose be blocked with a valve or does the h2o need to flow all the time? using a bypass hose set up.
there's not a whole lot of room back next to the firewall.
would using longer hoses, to bring everything out toward the fender cause any issues.
i've checked a/c operation and pressures, everything is within factory spec's. only thing i can think of to help, is to remove heat from the heater core.
any idea's or sugestions are welcome.
it's a bit warm in az this time of year... ... :eek:
thanks. .
