Rust belt?On my 14. Shock isn't seized. The weld was cold as all get out. Poor QC. Sag yes, easy fix but not acceptable in my book. Doesn't give me a warm fuzzy about the important ones!
While the weld is far from ideal the issue likely has more to do with what looks like a shock spacer that in there, I have seen this before and if that spacer is too long the shock will bottom out before the bump stop and puts a tremendous amount of stress into the mount. As we have been talking about get the correct length shocks and ditch the spacer!
Woaahhh.....
I feel like a complete idiot. I have looked at that spacer and questioned why the heck they would do that without ever questioning wether or not it was an add on from the previous owner.
Makes total sense. I am seeing the light!
Thank you AEdelheit!
Glad to help, Im guessing there is a spacer above the coil but often times the shock spacer is still too long for the coil spacer or if the coil spacer was removed then it would definitely cause the mount to tear off!
